1996 4.0 4X4 Ranger Ex Cab.
M5OD-R1
I'm about done with this truck. I've spent two full weekends under the truck rolling round in oil.
I recently had my transmission (M5OD-R1) rebuilt by a local shop, while I had the transmission out I thought it would be a good idea to replace the clutch, master and slave cylinders and have my transfer case reconditioned by the shop. I installed the trans, transfer case, clutch, flywheel, slave and master, clutch hydraulic line this weekend. I'm tired and spent.
This happens to be my first clutch in a rear wheel drive vehicle, but I have done one in a front wheel drive with a buddy a couple of years ago. I don't know where I'm messing up. The clutch seems to have proper pressure and I bleed it according to the instructions and video, but now that I have everything back together, it will not disengage enough to shift into any of the gears without extreme force. I'm at a loss...
When I look into the bell housing you can see the slave pushing onto clutch, which, to me, looks like a significant amount. When the clutch pedal is fully released, the slave cylinder appears to have a slight "wobble" to it, I have no clue if this is normal or not.
I really, really do not want to pull it all out again if there is something that can be done from the outside... please help. Thank you.
M5OD-R1
