86MUDRCJ
That depends on what your plans are.
What do you want to do with it?
Do you plan to tow with it? If so, how heavy is the load?
Are you running an overdrive trans? If so, what trans?
Is it your DD? Is it a fuel mileage build? Is it going to be off-road only/mostly?
Do you run highways all the time or not very often?
How much power to you want the motor to make?
(go into detail, dont just answer the questions.)
These engines really like to be between 1700-1900 for the best economy. If you're running the highway a lot, plan for that RPM range at your normal cruising speed and base your tire/gearing off that. Above 2000 rpm the mileage really starts to drop off quickly, the motor itself can handle it all day long.
I do drive the truck everyday so yeah it'll be my dd
As far as towing a small trailer,14ft alum. Fishing boat, or a trailer to haul a car. So torque is a big reason why I want to put the diesel in
Trans wise I haven't decided yet but prolly an od Trans.
Fuel I want decent but not to where I have no power.
I want to be around 350hp.
I drive highways most of the time but again I drive back roads a lot too.
I will wheel it but not too much considering I'll be driving it daily.
