Tejas TJ
- Sep 23, 2016
I have an '02 2.3l with 124k that I've consistently had cooling system leaks with since early last year. The thermostat went out pretty early on and then it was ok for a while. I then had a leaky heater control valve that caused the truck to overheat on me. I was told I should go ahead and replace the fan cluth and water pump since the truck had over 100k on it, so I replaced the heater valve, fan clutch, both radiator hoses and water pump. The truck ran ok for a bit, until the thermostat gasket leaked, replaced The whole thermostat with a lifetime warranty. Then the heater core, replaced that (what a beating), then the radiator leaked. Then the truck didn't leak all the way until last week when I noticed coolant under the truck and the upper hose was leaking at the motor, so I tightened the hose clamp and it was ok until later that week when the thermostat gasket started leaking again. Took it right up to Oreillys under warranty and replaced that last weekend along with a new radiator cap. I also rented the headgasket tester with the purple dye and did that on a cold and warm motor and got negative results on a blown headgasket. Today the radiator is leaking again. Any advice would greatly appreciated.
