Ignition Wiring
92V8ranger
Hello I was wondering if someone could tell me if I can use the mustang ignition wiring harness on the ranger. I'm using a 88 Mustang Fuel Injected harness out 0of a donor vehicle. Much help would be appreciated. Thanx
I spliced the wiring harness from donor to wiring harness of truck i was putting it in. You can obtain most of the wiring diagrams from auto zone. Hope this helps.
Thank you and can u tell me what wires u spliced into and where they are located. Thanks once again
You will just have to get the wiring diagrams for both vehicles and see whats what. Maybe you have the buxs and can afford to buy a custom made wiring harness which are available...heres a link to1 place that has the custom harnesses http://www.enginewiring.com/ there's a few others out there. Your donor motor is different than what mine was and for me to remember which wire went where, well lets just say ive slept since then. You need to make sure all your power leads for relays and all your power feeds for the positive and negative feeds to your computer are hooked up.
