ignition question
Bryan22
So-Cal babay
94 extd
i just tested resistance between corresponding terminals on my coil packs. on the dirvers side coil pack i got 15.3-15.8 and the passenger I got 16.1-16.5 the book says it should be 13-15k does that mean the coil packs are bad?
If you don't have a CEL, along with misfire codes, your coilpacks are fine!
thanks bob, i figured it out. turned out to be bosch plugs causing all my problems.
