- Feb 5, 2008
- Age
- 75
- Centralia, WA
- Manual
I Dursparked several years ago and I'm using the ignition compontents that were OEM with a '76 Pinto. My rig is running rough lately and lacks power. Checked timing and its right on. I replaced the distributor as the vacuum advance diaphragm had gone bad. Still runs rough and lacks power at cruising speeds. It needs a new carb and I've got one on order but that should only affect idle problems. At frst I thought it as a vacuum leak but now I'm beginning to think it's an ignition problem.
My question is this: Could it be the coil or the ignition module? Do those things malfunction without giving up the ghost completely or are they the type of thing that they are all or nothing, i.e., they either work or they don't?
Steve
Steve
