NMB2
July 2010 OTOTM Winner
OTOTM Winner
Solid Axle Swap
Ive been having an issue lately with my duraspark overheating and started checking voltages. Power going to the box and coil is pretty weak. I noticed that when the truck is running, If i turn the key switch slightly, inbetween run and start, everything lights up brighter, tach goes to where it should and spark is much stronger. I replaced duraspark box, coil, and ignition switch.
What else could cause this? Voltage regulator perhaps? Why does it get more ower with the key in that position vs run?
