Ignition Module Mounting Location
belovedb2
As you all know I am doing a 4.0L swap into my 86B2. I have the old engine out and the new ready to go in. I am presently laying out the 4.oL engine compartment wiring harness. For anyone that has done this where did you mount the ignition module? On the doner it mounts on the RH side just inboard of the head light. However, on the B2 there is no space in this location since the air intake hole is located there. Any ideas about the mounting? Any ideas about changing the air intake hole. Thanks in advance for your suggestions.
I am going to mount mine just to the drivers side of the radiator. Mine has a opening there in the radiator support that would let air pass over the fins on the heat sync.
Thanks. Turned out that is where I mounted mine. Toke a small piece of aluminum sheet metal and used it as a bracket. Mounted the bracket to the RH rad support. Looks good and is strong.
