a-5 freak
I am installing an Audiovox APS-596a in my 1991 ranger xlt 2.3l 5 speed and am having an issue with the starter inhibit. What wire do i tap into to inhibit the starter? I already have the relay. Any help would be apreciated!
EDIT: i found a wiring diagram for the relay i am using and it says that on terminal 87 i need to splice "From Igniton switch" on terminal 30 i need "to starter" and on terminal 86 i need "12v+ ignition". does this mean that on terminal 87 i need to splice the ignition wire closest to the drivers seat and on terminal 30 i need to splice in the side of the wire closest to the fire wall? and the terminal 86, do i just tap into a constant 12v+ source? like the source that goes to the fuse pannel?
