rangerpilot
- Nov 28, 2013
I have a 99 Ranger 4.0 V6 4x4 that is having trouble starting on cold mornings. I have done a little research but I am lost at how many problems can have similar symptoms.
So far, all I have tried to to replace the fuel pump relay. Now I don't hear the pump coming on when I turn the key on. My plans today are to...
1) Replace fuel filter...in case there is some water in the line that may have frozen preventing fuel from getting through.
2) Check fuel pressure with a loaned tool from AutoZone
3) Spray intake with starter fluid and see if it fires.
Based on the outcome, I have a fuel pump ready to be installed if needed but I am afraid it could be something else (pressure regulator, injector, etc.). Assuming the truck fires with the starter fluid, what should really be my next step.
The truck will crank all day until the battery dies...so far it only has trouble starting on cold mornings. Hopefully this afternoon, my tests will prove solid results so I know where to go next.
Of course, ideas are requested and welcome!
