You are assuming that all the calls are about a failure problem with the devices, or quality as you put it. I would bet many of the calls are about how to install, or wire correctly, or what devices to use. Some of the performance devices can be a little tricky.Check out this thread from the MSD forums, especially the last post!
With this number of calls / day, I would say they have a major quality problem!!!
http://www.msdignition.com/forum/showthread.php?t=12538
I am not of the school that only the OEM can make quality products. And even with all their rigid testing, etc., they still have a garage in back of most dealerships, and tons of service bulletins.
I have had few problems with new aftermaket products. The re-built stuff is a different story.shady
All companies have a way of returning their products, even Ford. It just so happens that MSD uses the RMA (Return Material Authorization) process.
ALL PRODUCTS FAIL, EVEN FORD, CHEVY, DODGE, HONDA, TOYOTA, AND NISSAN PARTS FAIL.
Bob is an idiot.
How would you prove this statement? I don't find this to be true of the parts I use. Maybe your garage has problems due to other factors.The aftermarket ones just fail at a much higher rate!!!
