was already planing on doing 15X8's with a 4.5 back spacing. reason im hopeing the 35's will work is because i already got a set of 35's, off my bronco2. and im trying to be cheep. if the 35's will work then i can save myself the $$$ to buy the 33's. reson i assumed the wheel barrings would be the issue is, because on my old ranger (2000) i have 32's on it and had nothing but issues with the whell barrings. but i owned that before i had my b2 and i beat the snot out of it. i dont think im going to need to regear, but i could be wrong. my 2003 has the SOHC 4.0l and 4.10 gears. i run 4.56's in my b2 and it does just fine with the 2.9l and the 4.56's. so i would think that sence the 4.0l has almost twice the torqu i could give up .46 in the grears. but if i cant fit them all this is for nothing. still not sure if i will be able to. im going to be puting in a 3" body lift in withing the next month or two, and am willing to cranck my tourtion bars a little if i have to, but dont want to max them out. i took a look at the tech section to look for a fit up. and did see the ranger with the 3" body lift "major" tourtion bar crank ans 35X15.50's. but from the pic i cant even tell if the truck could turn with them tires on it, and i dont want to do a "major" T bar crank, and the 35's i have are only 12.50's any way.
