kennykenny
I recently aquired another front diff with 4.56s to complete my gear swap. Before I pull the old and put the new up I am putting an Aussie in...here is where I ran into a problem. I have knocked the roll pin out of the carrier but the crosspin is only notched on the ends and it hits the ring gear before there is enough room to slide the axle in to remove the c-clip. The ring gear is not grinded either. How would I go about removing this? It looks like it'd be way too much to grind off the gear to get the pin out. Any input would be greatly appreciated.
[/IMG]
