Idling
87danger
CALI....
So i have a 87 ranger 2.9 v6. I dont understand if this is right but when i start my truck it jumps to 2 grand rpm then drops right down to about 9 hudred rpm. Should that be happening or shout it being keeping a higher rpm for longer???
Is it a manual or auto trans? My 87 ranger manual trans. if I start it with the shifter in like first gear with the clutch pushed in it revs up hard than idles down. Now if I start it with the shifter in neutral and the clutch pushed in it does not do it at all. i don't have a clue why it dose it
I dont know these engines well.. but in my thought it sounds right.. if it was a cold day i could see the revs staying up but there is no need for them to once the computer detects the operating condition.. but again.. i dont have any knowledge of these engines
It does it no matter what... cold....warm it jumps up then drops and its a stick!!
MAybe its just its way of yelling out at the world.. HEY IM A BAD A** ranger... the lower case ranger is where it dies down
Wait what is cold in your case.. cold in my case is like -35 C
Does it go back to normal idle after warming up?
Several sensors may in play, the IAT, ECT, TPS . . .
See if it has any codes that won't pull a light.
I have the issue of hunting idle and hard restart sometimes.
I haven't pulled the codes yet as I've been working on the other truck and
fixing things that I fixed before :icon_twisted:.
