- Jun 22, 2010
- Manual
Vacuum leak unless you didn't clear the ecu after replacing the IAC.
Yours is likely the IAC. Replace, clear ecu, then run it for at least a few days without the ac or defrost.
Yep. Replaced the IAC valve and the TPS (just for shits and giggles). Also, cleaned the throttle body. Its driving nice now. No more high idle with or without the a/c.
