pat julian
- Feb 15, 2014
Back again this week with another minor problem.. idler pulley on my '93 2.3 literally spun off the bearing as i was driving about 10 mph...limped into a parking lot..I work for a major parts supplier..so I call my work..have a pulley delivered to my location..(i carry enough tools with me to do most any repair)..and had the new pulley on in a few minutes..this is the second idler pulley I've replaced in 6 months..roughly 40,000 miles..and it was metal...new pulley (ac/delco) is plastic as was the original ford pulley..my question is the note in the box said i may or may not need the washer depending on application...how do i know if i need the washer behind the pully ?? amazingly when the old pulley desinegrated..i found the spacer washer on the sway bar underneath...so i put it behind the new pulley,tightened it ..and it moved smoothly didn't drag...installed the belt ..and went on my 250 mile parts run...BUT how did that washer get off the mounting bolt ?? the remnants of the bearing were still on the bolt..no way i can think that the washer could have been slung off..glad i found it..but concerned whether or not i needed to put it back on..also bought another pulley to keep with me..any ideas on how to know if you need the washer ?? thanks ..pj
