Daniel_187
Ok 2002 4x4 4.0L 5speed, I have been having problems with the truck when I step on the clutch the RPM's go up to 3000 and hang there for a little bit and fall back to 1100-1500rpm's or when I come to a red light and shift out of gear its revs up to 3000 rpm's and hangs for a little. I have gone over the usual suspects, cleaned MAF, cleaned IAC then replaced IAC, Replaced TPS, Replaced PCV. any Ideas before I take her into the shop? the motor is stock and if its a vaccum leak where do they usual occuar?
