- Aug 28, 2024
- Age
- 47
- Matagorda
- State - Country
- TX - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Manual
- My credo
- If you expect the worst and hope for the best, you're already planning for failure.
96 XLT 2.3l Lima 5spd, engine, regardless of temp, will fluctuate the idle between 300 and 900 and doesn't level out. I have replaced all 8 plugs and wires, air filter, oil filter, IAC, PCV and fuel filter. I have seen a few other threads refer to possibly TPS or MAF, but no info on how to test them before I just go throwing parts at a problem. The things I have done up to this point were already scheduled to be done any way. If I don't keep the throttle slightly depressed at idle, it will slow down enough that it dies. Can any one point me to a spec sheet or a guide of how to test the TPS and MAF and what readings I should be showing from my scan tool read outs?
