- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Automatic
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
So after many failed attempts for a dash mounted tach I got a tach kit meant for a diesel, it has a sensor that mounts to the alternator as its signal. Since it has to be calibrated Im not sure on where the idle rpm would be. One idea is to pull the driveshaft & have it idling in 4rth gear (its a manual) , use a mechanial tach up against the transmission yoke & see where it is, possibly turning the idle speed up to 1,000 for the calibration. The instructions say to check it at cruising speed but I have no idea what the rpms would be @ 55 or 60 mph with 4.10’s. from what Ive seen rpm could be anywhere from 600-800 at idle when warmed up. seems like quite a variance.
