Idle Problems, . . cluesless
producer87
I just purchased a '96 Ranger with a 3.0 V6 in it. I got it and it did not run. I checked it out and found that there were absolutely no vacuum hoses anywhere attached to the engine. . . I had a old 2.6 4cylinder from a 97 ranger. I took the vacuum hoses off that one and put them on the v6. Now it cranks with ease. Now it runs great for like 15 secs and then just slowly cuts off. Can anyone help.
Much appreciatted!
Idle air control?
Do you have a guide your working from for the vacuum system? You sure you got them all?
Well see when it was running I completely disconnected the IAC and it went dead when I did that, plugged it back in and it runs fine. . or as good as it is. I believe I got them all . . . I used the guide on the Ranger under the hood, . . .close to the hood latch. . . my father suggested the fuel pump . . . dunno tho. . .
Not to get you over hopeful, but the computer may not know how to deal with the current state of things. It may act better with just a short bit of running.
Thats the prob. . . it won't run longer than 15 seconds. . .
Are you saying it wont run for more than 15 seconds even if you press the gas slightly?
any smoke?
any unusual noises?
check engine light on?
how does the business end of the plugs look?
are the plug wires in good shape?
what do you know of the vehicle's history?
My first instinct is, if it dies in a few seconds even if the gas is gently pressed and there aren't any funny indications, I'd be looking at the fuel pressure. From there, if I didn't know much about vehicles (including diagnosing modern engine management), I'd probably spend 60 bucks for a dealership diagnostic.
Not much, I just know it was a company truck for Purdue chicken farms. . and then somehow ended up at my neighbors house sitting up. He didn't need it, he just bought it. Hes a high roller Farmer. . .lots of money.
Everything seems fine. . . spark plugs. . spark plug wire. . all of it. . . . and no I can not give it gas. . . . if i do . . i have to be EXTREMELY gentle , . . I mean EXTREMELY slow if i do give it gas or it will chug off!
Does kinda sound like a fuel pump problem. . . ? I have a great condition 4 cylinder Ranger same year model, sitting around. . . (blown up motor) that has a better looking gas tank and all . . . . . maybe switch them. . . but then lthat leaves the question of Pressure tolerance for the 4 cylinder, and the V6 . . . same tanks and everything tho! . . . .
It could be anything related to the fuel delivery.....pump assembly (strainer/pump/regulator), wiring, grounds, relays, even the PCM.
Dont shoot blind, get an EFI fuel pressure guage and the specification, and find out.
Got it!
It was the fuel pump! I took the gas tank and pump from my 2.3 4cylinder model and switched them. Works perfectly! Thanks for all the help!
Thats really cool...love it when the fix doesnt take much troubleshooting.
