C.Fuller305
I have a 1994 ford ranger 4.0 v6 4x4. For some reason my truck will sometimes idle at 2200, 1000, or 650 rpm there is nothing that is done different that will cause the weird idle. I have replaced the fuel and air filter, Injectors, cpu, Idle air control valve, Throttle position sensor, and I adjusted everything so that it would idle at 650 rpm. I made sure everything was tight and torqued down but my idle wont stay consistent. I have had a shop rewire my mass airflow sensor and I checked the voltage and ohms going from the cpu to the mass air flow, and found no problem. My 02 sensors have been replaced and are operating properly. I really need to get this fixed because it is eating up my gas and with these prices stuffs not cheap. Any suggestions will be tried
