I have a 1987 Ranger XLT with a 2.9. All of a sudden it started running rough at idle. I have installed new ford plugs, added injector cleaner to the fuel tank, replaced the IAC and TPS, cleaned the throttle body and adjusted the idle stop per instructions found on the forum. It is a lot better but still idles rough until it heats up to operating temperature.
It runs smoothe at higher rpms. I have a code reader which only indicates a code 23 fault which pertains to the TPS which I have just replaced. Any ideas?
Freedom5
Freedom5
