- Mar 6, 2020
- State - Country
- MI - USA
- Vehicle
- Ford Ranger
- 4.0 V6
- Automatic
- Total Lift
- 1-1/2 inch front leveling
- Total Drop
- Stock
- Tire Size
- 31/10.50/15
- My credo
- What's the worst that could happen?
Backstory...
I picked up an ECM from the pull yard awhile back from a matching 94 4.0, 4wd - rare to find one still in the vehicle let alone from a matching Splash model. I had already replaced the 3 capacitors in my stock unit, but the board was still a bit sketchy. It ran very well with the new capacitors until recently and starting running rough. So I replaced the stock unit with the pull yard unit (which was very clean inside) and the performance was noticeably better - still threw a 157 code, but still way better than before.
The idle issue happens when sitting still, in gear or in park, foot off the throttle, idle at about 8-900 rpm. After about 3-4 minutes the idle would drop to 600, then pick back up. then drop again. The cycle repeats, dropping progressively lower until it finally just stalls. It starts right up again and rinse and repeat.
I'm about to go out and go thru the 157 chase, but thought I would ask if there may be another unrelated issue.
Thanks for any input.
R
R
