Identifying Positive + Negative Speaker Wires
Either the voltmeter suggestion or looking at wire colors at the speaker will answer your question with no ambiguity.
50/50 chance of guessing the right colors. If you get it wrong the first try, 100% chance on the 2nd try.
Care to share your findings????
This was the correct way for my ‘99. Luckily this was the method I followed before finding the other way.
  • Identifying Positive + Negative Speaker Wires
Now that we've sorted through all this... What are you trying to do?
You shouldn't need the wire colors for the radio if you're using a proper adapter harness. Also - if you plug in the adapter to the factory wiring, you'd be able to immediately see what crosses to each factory wire from the labeled wires on the adapter.
