idel too high ...problem...but not always???
Thetford Mines, Quebec, Canada
hello
My 2005 Ranger 4L have a idel problem from time to time...
once in 2-3 days the rpm at idel speed climb anywhere from 1500 to 2500 rpm...
and it's worse when the engine is cold...
sometime I press the clutch...the rpm should drop to about 750...but sometime it stays at 2000???
this is kind of tricky when you wait at a red light with engine reving at 2500 rpm with the clutch at the floor!!!
what should I check? what can be the source of he problem???
remember...some days the engine run just perfect...no high idel speed...but some other days...it's an other story!!!
Clean the IAC, it controls idle.
See if that helps.
