Joelzme
- Dec 29, 2007
- Age
- 49
91 2.3l 2wd
I have had to replace the ICM on this vehicle twice. Recently she has been running bad, replaced the PCV, spark plugs and wires, cleaned out EGR, etc, still no relief. Took to Autozone and the ICM is bad, again. They replaced for free.
I have exposed all the plugs wires around the ICM to look for chaffing or split wires. Nothing. I cleaned the wiring harness where it plugs into the ICM with electrical contact cleaner and greased with dielectric grease. She is bolted to the intake manifold securely with 3 small bolts (there is no 4th bolt receiving hole on my manifold for it).
I have heard that over time heat will break these down, but that area of the truck is not that hot. There have been issues with this same type of circuitry breaking down when attached to the distributor. This is the 2nd new one (Duralast) in the past 4 months.
Any information that you guys might have about the problem, or what worked for you to get rid of it would be really appreciated, no matter how small.
Joel
Joel
