craig
this is a new module, from napa, it seems it is sending no signal to waste side coil pk right side 2,3 plugs, that is the right side wire to the plug for the coil pk. that indicates bad icm right? I had put a wire to ground from icm left top hole, no screw hole in engine this is ground, right? my make shift ground for icm goes to neg battery. used dialectric grease on icm back to mount would other ground other than battery be better? thanks and greetings all.
