JerrySab
- Jul 11, 2020
- Age
- 44
- Los Angeles
- 2.9 V6
- Automatic
Hi all!
I'm trying to zero in on (yet another) slightly high idle issue. 88 2.9l idles at 950-1100 when warm. Every so often, infrequently, it'll drop down to 800/850, which I believe is the target idle when warm. I'm curious if there's a break along the ECM wire going to IAC, or something that would be causing higher resistance or otherwise messing with the data stream that's preventing it from fully closing. Also, wow the gas mileage is terrible. SO I suppose the technical question is: does a higher voltage signal cause IAC to open further (and thus raise idle)? Or is it the other way, a lower voltage signal would cause IAC to open further?
My guess is a full 12v would open IAC widest, so no resistance. Further, a closed IAC would receive either low or lessened voltage. Or none at all? It's really not a super significant issue, other than I'm super motivated to get better MPG now that gas is a pound of flesh/gallon.
I'm 99% sure it's not a vac leak. Truck idles at wherever throttle screw is set when IAC is unplugged. I have 18"+ compression, steady. IAC is Motorcraft. Only front of mind culprit could be bad alternator/voltage regulator. It's very squeaky, which could also just be bearings. I have a MCR upgrade that I haven't installed yet.
Thanks friends!
Thanks friends!
