DangerRanger2.9
- Sep 24, 2010
86 2.9L, 5 speed, 4x4.
My IAC is not operating. The IAC is brand new. The red wire has a good 12+ volts with KOEO, and KOER. The grey wire (ground, the control for the IAC) has ground when key is off. When KOEO, and KOER there is no ground. I see no sign of ground with key on, even when starting, or when engine is running and trying to idle but starving for air. If i jump the grey ground wire to a ground source, the IAC opens as it should, and idle shoots up, other than that, the IAC is ALWAYS closed. WHY IS THE COMPUTER NOT OPENING THE IAC?
Thank you so much
Base timing and advanced timing is correct.
Codes Are:
KOEO-
11 (pass)
Memory-
18 (ignition tack signal erratic)
53 (TPS too high)
63 (TPS too low)
33 (EGR did not open intermittently)
KOER-
33 (EGR did not open/respond during test)
13 ( IAC not controling idle)
25 (knock sensor not tested)
Codes Are:
KOEO-
11 (pass)
Memory-
53 (TPS too high)
63 (TPS too low)
KOER-
