RustedRanger
I took my IAC valve off and cleaned it with throttle body cleaner and blew it out with an air hose and now my truck barely runs. Can it fail or break bad enough to cause a bad vacume leak? If I unplug it with it running it dies(like it should) but could it broken inside allowing vacume to leak? It has 147,000 and is the original. I wonder if it had gunk built up around the plunger and when I removed it by cleaning it maybe it no longer seals? Can the plunger itself come apart where it seals? Right now it's pretty much undriveable. Thanks.
