IAC Cleaning?
k3eaxk3eax
Please tell me how and with what did you clean your IAC --- idle air control valve.
Al
Probably the best way is to get a throttle body gasket, pull the TB and pull the IAC and TPS and anything rubber, soak it in carb cleaner overnite then blast it off good with the hose. you can use the carb cleaner to clean the IAC. When you put it back together dont overtighten the throttle body on and always use a new gasket. Put a new PCV valve on at the same time and clean the MAF with electrical cleaner or rubbing alcohol. Disconnect the battery for 1/2 an hour when cleaning or changing a sensor to reset the computer. GL
