I will try it here BII
Sawz
Greetings. I tried it in the BII forum but not getting any response so I thought I could try it here maybe
I have a new to me project that I picked up for a song, and am trying to get it running, I know it will be something simple. Hopefully
Im not getting fuel so I tried tracking the voltage back from the battery to the pump , here is what I found
1 ( not related, or is it?) tailights have a dim glow when key is on. light switch off
2. At the fuel pump relay I have full bat. power to lead. with connector disconnected, I have 6.4 volts at the two orange blue lines one going to the eca. one to the inertia switch.
3 Where is the ECA? and what is its job?
4.At the inertia switch which ohms out fine, and works manually ( i can physically trip it, and reset it) I get the same reading 6.4 volts on the lead coming in. When I jump it over to the line going to the pump, the voltage disappears.
5. I found two of the three ground wires at the battery negative side either cut or corroded ( to be fixed tomorrow), That doesnt explain the bleed through at the relay connector though
Any suggestions? Im wondering if this ECA or on the diagram "Electronic Control Assembly", if its shorting out inside somewhere, and bleeding backwards to the connector. I cant find anything as to its whereabouts though or tests for it.
I think you have a bad connection. Its good enough to test ok, but when it has a load put on it, it can't push it.
Check all of your grounds, the lights being dimly lit with the switch off is classic for a bad ground. The "ECA" is what runs the engine in your truck, your odd voltage problem there could also be connected to a bad ground. I wouldn't condemn the "ECA" (= EEC) until you verify that you have good ground and power connections to both the fuel pump and the EEC
great thanks
Ill double check all grounds I know I have some bad ones I just didnt know it would lead to bleed through on other voltage issues.
