- Mar 31, 2024
- Johnson City, TN
- Automatic
Hey y'all. So I took the truck to work one day and when coming back home I noticed the oil pressure gauge dropped to the floor out of nowhere. Pulled over, checked for new leaks, checked to make sure oil was still present, tried to look through oil fill cap into valve covers to see if valve train was still properly lubricated. All seemed to still be normal. Assumed sender finally went out. I replaced the sensor and same result. Must be messed up wiring, right? Continued to drive to work for a week in the thing, including interstate driving which ya'll know the 2.8 has to scream a little bit to make it up some of the hills on the interstate at a decent speed. If oil pump wasn't working then the engine surely would've started knocking at the least, right? Moving on, Fords oil pressure gauge is fake anyway (goes to middle as long as 5psi of oil pressure is present) so decided to add a mechanical oil pressure gauge. So here's the kicker, after I installed that and try to test it out, no oil fills the line...no oil pressure... Gauge was seemingly correct. I removed the oil pressure sender adapter from engine block and made sure it wasn't clogged in anyway, I did the same for the hole in the block. Still no oil in the line. Attached gauge lines directly to block. Still no oil.. I'm stumped, how has the engine not blown up yet? The thing still sounds fine as the day I got it running correctly again about a year ago now. Any recommendations or something obvious I missed? Oil level is good, engine sounds fine, perfect operating temperature, but seemingly no oil pressure.
