crash192279
- Jan 20, 2012
ok heres the story, i got a 93 ranger, 4 cyl,(with 8 plugs), stick. when i got it it needed a head gasket got that done and it was running great but the check engine light was on found out that the o2 was bad and the cat was backed up. got that fixed and then it was tossing codes out like crazy 224,222,223,998,90 and i believe 145. had everything tested and found out it was the Ignition Control Module and the Coil. got that fixed but heres the crazy thing starts right up and no check engine light!!!! idles great but if you step on the gas
(like leaving a light) it falls on its face and will die sounds like a diesel truck shutting down. but it only does it when around idle once you get above 1700 rpm it runs like a top. what im asking is does the truck need to relearn anything? is there i known issue with a sensor? any help would be great!!!!
