goldxlt
ok so i just got my truck back from the shop, i had a wheel bearing replaced and i drove it home with no problem and then i headed out to my girlfriends house and started out good. i noticed lots of vibration in the stearing wheel once i hit highway speeds but figured it was bad tire wear(long story due to the wheel bearing im guessing) once im off the high way the vibration is almost non existant however there is a knocking when im comming to a stop and it is speed related. i round the turn and the front wheel to me felt loose( could have been in my head, thats my biggest fear) so i pull over and take the wheel off to inspect it. the lugnuts didnt seem horribly loose so i check everything else, i didnt notice any obvious obstructions and everything seemed fairlly tight, about the only thing i noticed is that the studs didnt exactly line up nicely with the holes in the rotor, (they were towards the rear of the truck) im not sure if that maters and it seemed to have a very slight amount of movment. i didnt have the time to check out the other side so i just took it easy to my girlfriends house. any one have any ideas, its about 25 miles up to my shop, think i would be allright heading up there? thank you
