brother rat
I know this has been hashed and re-hashed. I've read up a lot on this forum and other sources. Here's the deal: '94, 2.3, auto, 2WD. The 2.3/auto is just too anemic. So I'm considering the options and I'm just looking to bounce some ideas around and get feedback.
4.0 swap? 3.0L swap? I'm in California so engine swaps like this can cause some complications. Turbo? I want to keep the auto trans. Going the turbo route means losing A/C? Swap in an SVO/tbird motor or add a turbo to the current motor? A turbo build would certainly be mild, reliability is king.
Currently it rolls on 14" wheels. They don't bother me too much, but I would like to go to 15's and tires somewhere between 225's and 30's. That would mean regearing. Current axle is 8.8" (swapped by previous owner), I'm pretty sure the ratio is 3.55. I could just keep the current engine setup and regear, but I live in SoCal, so I need to be able to consistently run 75 mph on the freeway. L/S will be in the works regardless.
Lots of different options and variables. I'm trying to get some feedback. I'm pretty good with routine maintenance, but I'm no mechanic. The last engine swap I did was in Mexico, using a 2x4 nailed to a tree trunk as an engine hoist and the only tools we used were a couple of crescent wrenches and a hammer.
Anyway, I'm not looking to build a racecar. Previously, I had a 4.0L Jeep Cherokee and I was pretty satisfied with that level of performance. That's kind of what I'm looking for. Again, reliability is king.
Thanks!
Thanks!
