96Indyram
I have a 87 4x4 with the 2.9 V6 and the 5 speed manual transmission.
the transfer case is the manual lever also.
the truck started acting like the parking brake/ rear brakes were locked up.
I try to drive forward and i have to really give it hell to go forward, but in reverse it does fine.
I jacked up the rear of truck, put the truck in neutral ( 5 speed) and with t-case in 2Hi ...and I spin the rear tires by hand..they are free and turn easy ( alot of slop in differental)
but the rear drive shaft wont spin when I tried... I grab a big set of Pliers and clamp on it and it is real hard to turn.
I put the transfercase in neutral and the rear drive shaft spins free and easy, and turns the tires like it should.
In neutral with the engine running, i can push the clutch in and out and the truck will move slightly, and you can hear the engine rpms change.
I have a 84 4x4 with the 2.8 v6 5 speed, and manual t-case that I can swap out with if I have to.... I think they will interchange.
So I am thinking something is messed up /binding up inside the 5 speed .
Any ideas of what is going on?
Thanks Indy.
Thanks Indy.
