John Smith
- Jan 17, 2010
I'm the proud owner of what i hope will have enuf donor parts to start a 4banger/b2 i've been wanting to do.
I've acquired an 87' b2 that pumps air into the radiator..it really runs fine...just has a pressurized radiator..(head problem).and has a great straight rust free body
Instead of putting the 500+ or so in rebuilding the 2.9 I have been curious to drop a 2.3 into one..so i guess i have the parts now...
my question is have i gotten a decent year for the donor?...is the larger journal crank of the older motors desired over an 88?...which if i read right is supposed to have a smaller journal crank.
this engine is still in the truck but the head is off but is all there...it may have bottom end problems...and i can assume a major rebuild..but i don't mind that...if the crank is bad...what would be the most desirable option find an older block?...
I will be in this for the long run and bigger picture...i hope to keep one of these 4 banger 4x4's around till i can't drive anymore...and i like the options for parts for this motor vs: the 2.9 which i still have in another 88 b2...(wifes grocery getter)
I will just mod this 87 w the 4cyl for my hobby project...
as a side note the 88 4x4 trans and tcase are intact and supposedly fine with a new clutch....
anyway any input would be apreciated re: the year of this donor ...
regards:
JS
regards:
JS
