- Aug 11, 2007
- Southern Virginia
AllanD, are all '98+ frames modular...? (not just the supercab version?)
It would be an unique ride, but the turn radius would suck. Every tried turning around in a crew cab long bed truck?
Uhhhh... That isn't a "Custom frame", THAT is a modified Corvette frame.
LOL Ok but it's not.......it's Ranger with IRS
I'll tell you what this proves too: I've said many times that a truck is meant to carry the load centered over the rear axle. That riveted joint is weak, but it doesn't matter because the cargo half of the truck is like a wagon riveted to the cab half. The front axle capacity of any truck is not much over the curb weight of the front axle--with exceptions. All of the load carrying capacity is designed into the rear axle. This modular frame image makes it scarily obvious. Don't carry your depleted uranium collection in the front of the pickup bed.
GM has been doing this for years (so, I imagine have others) but they weld the sections together. I don't think any truck larger than a Ranger would have the joint that small and held by rivets. I've seen rivets that were worked loose with continous frame rails on two plow trucks.
Lol actually... its a corvette with a ranger body...
But the longbed extended cab idea would be awesome, especially for a 2wd long hauler. You could make the cab super comfortable and also be able to utilize all of the space in the bed as well. Even a topper if you wanted.
Althoug a mild 2" lift would probably do it good. so its not so low and stuff, because with a longer wheelbase your gonna high center on hill easier... nothing extreme, just enough...
Lack of locking hubs won't be a concern, the truck will be FULL TIME 4x4, or more precisely "AWD"
AD
=====================================The truck I'm building will have a front axle, 1998-up type with explorer outer parts
Lack of lockin hubs won't be a concern, the truck will be FULL TIME 4x4
AD
Actually I'll never own another 2wd ranger except to either part it out or convert it.
4x4 doesn't mean you MUST go off road, it's sometimes nice for it to be there
AD
AD
BTW, a 1993 Cab is going on this frame.
AD
