I-Beam Suspension Questions
ggomez2
Denver, CO
Hello,
I have a '94 Ranger XLT 2WD and have thought about trying to level off the factory rake the truck came with. Currently I have this truck completely stock, 15" rims on 30x9.5 tires. I am trying to figure out what my front lift options are (Spacer, longer coil) as well as the adjustable camber bushing upgrade. Not sure what degree adjust-ability I'll need to get a good alignment done. Thinking about all of this because I'm having the stock (failed) Radius arm bushings replaced by a local shop; while it's there I'd like to have them also do the cam/lift. The coils are stock with about 220k miles on em.. should I just replace them?
Any suggestions?
Just use the washer mod found in the tech section of this website. I used three on mine with plenty of threads left on the main bolt and it aligned fine. If you have problems with alignment, you can get high angle eccentric cams to make up for it, but i don't think you would have to just leveling it out.
