i am having problems with egtting thorugh inspection
unknown
they said my fuel cap & tank failed!
well i replaced the cap $5.00 now i looked into the filler tube its $300 from ford :shok: well fk that!
i was tring to see if any1 else had this problem & se what they did to pass!
maybe little rigging of the filler tube is what i mite do! or put a disc in the filler tube run through inspection then pull it out! can be that bad since i dont smell gas & dont see any fuel on the ground when i over fill the tank!
any suggestions?
our shops are at dmv so they run everything on the dmv grounds! idk if there making money on doing it that way or not! i will try another 1 tho since we have 2 with-in 15 miles of each other
Thats one thing I like about Ohio no inspetions as long as its rergistered, insured, and has working lights you can drive it!
I don't like inspection either but there are cars/trucks that from 60 ft away, you can tell they ought to be off the road.
Dave
ye ai have a mechanic he helps me work on my vehicles for free if i need the help! ( But I Need To Be right There Learning)
yes that is good for when he is busy with side work or what ever but if he knows i,m having problems hes there to help!
we were going to lift the bed & just get it though inspection then on a later date do the work that needs tobe done not just get around it then fk it forever just till i get the money up for the part & to still provide for my family!
http://cgi.ebay.com/94-95-96-97-For...trkparms=65:12|66:2|39:1|72:1205|293:1|294:50
This is where I will get my filler hose later this year. My mechanic friend is going to do it on side for a 100.00 dollars. There are less expensive ways out there. Find a couple of friends that can help you lift off the bed and replace it. Should not take more then 2-3 hours to do even for the beginner like me.
that is perfect right up my alley! $65 is much better then the 100's+ thanks i will get this asap & also going to look for the sending unit through them also!
:icon_thumby: :yahoo:
