- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
I'm starting to think the Bronco II loves seeing me work on this during any summer/warm months. The other issues with the blown radiator, exhaust gasket blown out of the manifold (thanks for all that helped with that one btw)
Now I've got something oddly interesting. The truck has always had a lot of white smoke when I first start it up. Normal condensation is what I figured it was. Last few weeks? I've been driving the wife's VW beetle to work every other day to save the $$ (Her car gets 29mpg..the bronco gets about 17 lately)
Here's the rub: The white smoke gets pretty bad if I let the truck sit for more then a couple of days without running. I drove the truck on several trips on Sunday, and it was flawless--other then the white smoke when it started up. The smoke clears up after about 10 minutes or so.
Today I go and start the truck up, as I didn't drive it yesterday and wanted to maybe take it out later in the day. The engine turned over 1/2 a crank and came to a sudden "halt". Just as if the hand of God reached down and grabbed the crankshaft. I attempted a couple more times to start it, and it finally spun over normally and fired up. Engine vacuum is at times low when it first starts up and it's a tad rough with the idle for a few minutes until it settles down. (It's been that way for many months)
The white smoke reappeared soon after it started running and let up after about 5 minutes. No knocking (other then the usual noise for a 2.9) And it ran fine?
Here's what I think might be happening--and I would like some feedback to see what others think before I nose dive into more repairs and such.
I feel that the engine has a very small leak, maybe in the headgasket. When the engine hits running temp? The parts expand and the leak seals itself up. When the engine gets cold--The leak starts to slowly drain into a cylinder. In the case of this afternoon? The cylinder it normally drains into--Was at the compression stroke and the starter attempted to compress a liquid--bringing the engine to a dead stop. It probably finally cleared just enough space to allow the engine to spin over and it would have dumped the extra fluid out the exhaust--that would explain the white smoke, as it is getting burned off in the converter.
Our maintenance manager works on race cars and their engines and stated he thinks I'm right on what's going on.
My plan is this:
I drove the truck to the families house they are working on. My tools are all stored there. The truck drove flawless over to the house. I'm going to head back tomorrow and remove all the spark plugs. And if I do not see any coolant present? I will let it sit for several days with the plugs out. I'll then head back over on Sunday and disable the ignition and spin the engine over without plugs installed. I'm expecting to see a stream of water being ejected out of one of the cylinders when I do this. This should lead me to the side of the engine that has the fault.
As I said. I can drive this truck daily and there isn't any problems. A small amount of white smoke..very small..and it vanishes pretty quick. Give it a few days? I could use the truck to insect fog.
Can anyone suggest any other detailed testing I should do? I'm not going to bother with a block tester, as I can't afford the parts to do the tests. I figure if the coolant is entering the cylinder when cold? It should do so even more with the plugs removed. The engine has great compression (180lbs even) So I think the coolant isn't making it to the oil system. It's dumping just enough to be annoying.
And yes I've double checked the oil for fluid. Just has oil. No milkshake...Dipstick is on the full mark and has not been creeping higher. I think this is just a small leak that is only now starting to cause more issues--and maybe is getting larger so we can figure it out.
Ideas are welcome!
Thanks
S-
My plan is this:
Ideas are welcome!
Thanks
S-
