- Aug 21, 2025
- Chapin
- State - Country
- SC - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 4.0 V6
- Automatic
- Total Lift
- 0
- Total Drop
- 0
First post on the forum. I have 2011 ranger with the 4.0 SOHC with 145k miles. No timing chain rattle I can hear. I will be replacing a leaking thermostat housing soon. Thought it would be a good time to replace the hydraulic tensioners since I’ll have the throttle body off and the t-stat house out. I have Ford replacement tensioners purchased. I’m wondering if I will cause any problems if the engine is not at TDC. Also worry a bit about oil leaks since a few posts suggest it can be hard to get a good seal on the new tensioner. Last concern is whether a new tensioner will put too much pressure on the guides and precipitate a new problem.
Wondering if I should just leave the tensioners alone since it is running well.
Appreciate any thoughts.
