88 ford ranger 4x4 with a 89 5.0 HO and a np435 tranny with a np208 transfer case, So I decided to remove the clutch cable set up I made and go back to makeing it a hydrualic set up. Using the stock clutch master cylinder, however the way my exhaust is set up I cant use a push type slave cylinder so I got one of these. A pull slave
http://www.speedwaymotors.com/Universal-Pull-Type-Slave-Cylinder-7-8-Inch-Bore,783.html
I do hope the 1" stroke will be enough. Now I remember I read on one of the post there was a fitting that will adapt into the stock master cylinder so u can use a threded line. Anyone know the part number by chance?
