Hub/wheel seal
Tamsar20
Portland, Oregon
Doing new rotors and repacking the bearings. Bent one of the seals getting it out and can't seem to find the right wheel/rotor seal for my 1994 ford ranger 4x4. 22003A is printed on the old one, and the one i picked up from autozone was too small. Anyone know where I can pick up the correct one? I'm not having any luck.
Did you check Rockauto?
The part number may be different with different manufacturers. But you should be able to find that seal. Make sure you know which axle you have. For 94 it is most likely a Dana 35. But don't assume that. There is an article in our tech library to help you identify whether it is a Dana 35, Dana 28 or 28/35 hybrid.
Thanks, its the Dana 35. I looked up the specs on the seal and am starting to think that autozone sold me the wrong seal. Had the 2wd version in the box or something like that and I assumed that was not the right part # for me, I'll try Napa or O'Reillys tomorrow, I have the worst luck at autozone...
You're talking about the rotor hub seals? Got an image?
And was it the inner or outer seal?
I usually try Rock Auto to narrow down the selection(s) and go from there.
They show a ton of different brands for my 94 4x4
Thanks for replying, I got one at O'Reilly's no problem. The ding dong at AutoZone made me think it was an obscure part, but they had just put the wrong part in the box for the part I needed.
