Hub removal help please!
Alaska
So I'm taking my hubs and bearing assembly of for replacement of both. I broke the pvh hub trying to take it off. How do I get the guts out to access the c-clip inside? I'm working on it right now!
the end cap of the hub twists off to the left then you have access to the guts. look in the info section under permanently lock pulse vacuum hubs.
The end cap is off as well as some of the guts however there seems to be something holding the last part of the pvh hub to the cv shaft. I don't know what to do
