Howdy Ya'll! from TN
First off, I'd like to say what a great resource this is for info and advice. There is no question you can ask that someone here can't answer.
A little background on my truck: My uncle bought it new and drove it hard until he had ignition problems (The key cylinder had a bad connection in "run" and would die and then come back causing a backfire which eventually blew a hole in the muffler) so he put it in his barn for a few years where Mud-dobbers got into EVERY nook and cranny. My Dad bought it and put almost $1000 in it, mostly cleaning the fuel system and replacing the tank but it never ran well. I bought it for a work truck but 10 mpg made it too expensive. After fooling around with it, I managed to coax 15 mpg out of it (mostly by disabling eec system). It has sentimental value so I decided to keep it and fix it up. The general consensus is to Duraspark it, so that's what I'm doing.
I never understood why the engineers at Ford put the EEC system on a carbureted engine: It robbed all the power and mpg's. Not to mention what happens when one of the many sensors (temperature, vacuum and pressure) stopped working. Then I remembered that gas was $1.04/gal and the speed limit was 55 mph in 1984. Instead of making the engine more efficient and burning less gas, they added the EEC to control emissions.
I may have "Sympathy for the Devil" (2.8l's), but it's a good truck (or it will be when I'm done) and I'm going to drive it until the wheels fall off!
So, thanks to everyone and remember: "Rangers lead the way!"
Welcome to TRS~!
I know what it's like to want to hang onto something and do whatever possible to keep it...had my Ranger for about 14 years now and taken it through various changes and spent scads of money on it...
Anyway...glad you found the site and I know from reading there are many devoted 2.8 Ranger owners on here...even a few BIIs with them...so you should find what you need...sometimes what you don't want to hear comes out, but that's just the way it goes.
Enjoy!
What part of TN you from? I'm extreme northern middle myself.
Anywhere around Clarksville, SenorNoob?
Welcome to TRS, Daniel!
Kinda but not close enough. In between Lafayette TN, Westmoreland TN, and Scottsville KY. Right in the middle of those 3. You could probably find my truck in the yard on google maps by knowing that.
Daniel, you be a true mountain man?
