How To Test MAP Sensor
87Sturd
Washington
Can anyone tell me how or point me in the right direction?
i'll look in my book to figure out which pins to test. you'll test with the sensor plugged in and the key on. backprobe the signal wire, watch the voltage with 21inches of mercury applied.. it should be about .5V-1V. test at 0inches and it should be about 5V.
you could also test resistance.. but i don't know the specs on that. what kind of problem are you having and what is pointing towards the MAP?
