Today I took the Stripper's tranny and shoved it in the Turd. hmm, that doesn't sound quite right......
The Turd already had a clutch on it when i bought it, so i figured i would take it off and check its condition before putting the trans in. To my surprise, its a new clutch!
Also got a newer slave from "holyford86" on the forums.
the bellhousing bolts were actually a lot easier to get in than i had thought.
I used this
to get here
Used the hoist to lift the trans, just like how I took the old trans out. I let the assembly hang a little low before i put in the crossmember, and it made it much easier to tighten the upper bellhousing bolts.
oh yeah, in case anyone needs it, here are the measurements for the bellhousing bolts on a 2.9. the head of the bolt is a 13mm
also pulled some more stuff off the Stripper, including the petal assembly and dash wiring. kept the dash wiring mostly complete, since i may need some of it for the Turd.
swapped the (manual trans) computer from the Stripper into the Turd as well. opened the hood to try and start it. saw the brake fluid reservoir looked a little cracked, so i poked it. bad idea
also couldn't get the motor to turn over. that was a FML moment.
So now i gotta figure out how to get this thing started. when i turned the key on, i could hear (what i think was) the fuel pump. but no solenoid click for the starter.
I think there is a wire somewhere that told the computer that the trans was in P or N, and allowed it to turn over (this was originally an A4LD truck). Anyone know where that wire is, and how to "jump" it? basically i want to see if the motor runs before i spend ANY more money on it. I need to modify the wiring to where i don't have to have the clutch depressed to start as well.
I'm about to sift through the Tech Library and see if i can find what I'm looking for. Any help is appreciated
