How To Stiffen Leafs with NO lift?? or what to get?
jodom15sc
TN, homegrown in SC
So basically fixing up little things today like realigning fender, fixing bumper brackets, and fixing door locks and began to think about my rear leafs.
Now im at the point, I want to go to the 4wheelparts here and get an Add a leaf from them, now the 1st thing is that they sell short, long, and a thin pair. and issue number 2, I want to stiffen up the ride like the rangers with towing package, this way when I put stuff or even stand in the bed of my truck it doesnt look like its ass end is loaded down.
So should I get a short add a leaf? grab some from the pull a part? or should i look into something else? Oh and btw my leafs are in good condition as is, not sagging or anything.
Like I said before, just want to stiffen up the rear not lift it, just tired of the rear end sagging so easily. And I've looked at the tech library and searched and etc but everything is add a leaf=lift etc etc etc
Try the long and play around with swaping out the 2nd leaf and see it makes a difference.
Or just look into a HD set. I have a set if your interested.
well i probably should have said its a 99 2wd
and how much you lookin to get? they are doing specials here for like 30 bucks for add a leaf pair
the add a leaf will prolly lift it if you don't take out another leaf on the pack you might be able to do some frankenleafs with explorer leafs
Is yours a standard or extended cab?
ext cab
and thats what i figured, haha some frankenleafs might end up happening, i guess ill see what the 4wheelparts guy say,
There is a writeup on expo leaves in the tech section, You should def give it a shot before buying leaves. the JY is almost always 90% cheaper anyways.
